It is currently Fri May 24, 2013 5:19 am
Post a new topicPost a reply Page 1 of 6   [ 52 posts ]
Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: How do you pull of a SM helmet
PostPosted: Wed Apr 08, 2009 6:17 pm
Hey,
i was wondering how you take of a Powered Assault Commando helmet off one of your minifgs...because mine was a snug fit and the head won't come out of the helmet...i've tried tweasers, my fingers, water, pulling....and nothing works...so if you have and suggestions on how i can remove the head from the Powered Assault Commando helmet i would really appreciate it.
Cheers.
this is what is happening^^^
-S
Hound Knight = Favourite Decal guy. JasBrick = Favourite customizer.
 Post subject: Re: How do you pull of a SM helmet
PostPosted: Wed Apr 08, 2009 6:21 pm
Like with any other snug helmet, wiggle the helmet side to side. This will make it looser until after 10-20 seconds it'll slide right off the head. Also moved to the correct forum.
PostPosted: Wed Apr 08, 2009 6:45 pm
Yes, as stated above wiggle it about for a while. That is your best answer. I pull the bottom up diagonally and it comes off in about two goes.
PostPosted: Wed Apr 08, 2009 7:37 pm
Apprentice
Apprentice
I find it best to pull it forward as you pull up.
"I'll be what I am."
PostPosted: Wed Apr 08, 2009 7:41 pm
I have tried Gecko's way and it works a lot better than my method for sure.
PostPosted: Wed Apr 08, 2009 8:14 pm
I'm sorry but it's not really working,
it seems like its glued into the head (even though it's not), it just comes off the neck piece with the head still in the helmet
:-x
-S
PostPosted: Wed Apr 08, 2009 8:15 pm
:-x
-S
And have you tried the other suggestions of wiggling it left and right first? Like I said, it'll take a few seconds of doing, but you'll notice it move more and more and then just come off.
PostPosted: Wed Apr 08, 2009 8:18 pm
Let the head come off the neck. Go into your garage and into your dad's tool chest and get out the pliers, cause I'm sure no house doesn't have a set of pliers. Hold onto the helmet. Grab the inside and rim of the head with the pliers, and pull. I use my teeth for this...but there's a risk of the head shooting down your throat, so I don't suggest it.
PostPosted: Wed Apr 08, 2009 8:21 pm
Apprentice
Apprentice
Try, instead of pulling up, pulling the top forward and down.
PostPosted: Wed Apr 08, 2009 8:26 pm
Oh, or this one: again let it come off the neck. Turn the helmet over, and sit it on the counter next to the microwave. Put butter in microwave, heat. Pour into helmet around head. Make sure not to get any in the head. Reattach head to body, but upside down so butter doesn't go everywhere. Pull helmet.
